big PIA
2002 gl1800
My bike was was running a month or so ago and starter clutch went bad on me.
I finally tore the engine off bike and fixed it. Now when trying to start it it seems like there is no power, holding gas and cranking it is firing but running very weak and won't stay running so I can figure it out. Almost like weak spark or not getting gas. Looked at wiring, seems to be all hooked up. Hope someone can give me idea what to look for. I miss riding and need it going. All help appreciated. Surprised clutch worked at all because the pins and spring stuck in, sprayed with wd40 but still not coming out. Used parts off a parts bike I bought. Starter clutch I put in seems to work great
It is common that the ignition unit on the back of the engine gets installed wrong when the rear case is installed. There is a pin that must align with a slot in the shaft to get it back in time.
big PIA
2002 gl1800
News to me, did not do anything with timing from back of case. Now that makes sense that it sounds like timing issue but have no idea what to lok for, did not set anything at that end, just unplugged and plugged in wires. Please give me idea of what I need to do to fix please
big PIA
2002 gl1800
First time I pulled motor it took me hours.
This time I did not have everything bolted up yet, took it far enough so i could try starter. This time i had motor out, fixed and back on bike in lil over 2 hours.
It was that pin not lined up, I did not even realize it was there and it snapped pin when I put it together first time, I had spare motor from the prts engine I saved and used the back case off it to put together, together enough now and fired right up and ran good.
thank you for quick response last night. These are great forums to get info from. thank you very much for the help. It will be day or 2 before i can button it all back together but I know it will live again:):bow:
