My 83 GL1100 Radio and Clock lose their memory after I shut the bike off. Radio stations are not remembered and the clock loses it's time.
New battery, good fuses, cleaned radio contacts with spray contact cleaner.
Anybody else have this problem?
Check all fuses with a test light or meter on both sides of the fuses. They can look good but will be bad!
2nd the bad fuse in the left fairing pocket,which runs the clock and keeps the presets on the radio
The fuse for radio memory is in the fairing, behind the left turn signal.
Thanks Fitz! You were right on! There are 6 fuses back there. My 1 amp fuse was blown.
