HI All:
I have an 83 Gl 1100 Interstate. It was running good untill I let it sit up about a year without starting it.
I usually keep seafoam or stabill in the tank but may have not had any in it at the time.
About 6 months ago I started it and it did not runvery well . the fuel smelled bad, and it smoked and did not want to idle.
At that time I drained the fuel tank, and a couple of the carbs, added new fuel and fuel additives or cleaners.
A few days after that it looked like oil had dripped from three of the carbs as there was little pools of oil on top of the motor directly under the carbs.
Fast forward to today, I had to buy a new battery for it. I added a little more fresh fuel and it was not long before it started.
It did not start smoking untill maybe a minute after running. I notice the pavement under the left exhaust pipe becomes wet so something is not right although it smokes on both sides.
The motor actually does not sound bad and seems to run pretty well but does die at idle.The exhaust does smell, but it could just be the oil burning.
I am wondering if a bad fuel pump could be sucking oil into the carbs?
Since the throttle response seems good, I do not think the carbs are all gummed up.
I could run it a long time and see if the coolant level drops, that would tell me if the wet pavement is coolant or just unburned fuel.
Iknow burning oil means oil is in the combustion chambers, but seeing how it is dripping onto the top of motor when sitting it leads me to belive the oil intake is through the carbs.
Fuel pump?, PVC valve ?
Alan, in Houston
HI All:
Alan, in Houston
