Question I have the 83Interstate on a lift with the front wheel of the ground and turn the handlebars side to side. As soon as I return to the center position it seems like it grabs slightly. Worn bearings or can I try to lube it up? Thanks for any direction GF
neck bearings
Thanks for the reply Where can I find races and should the bearings be replaced also. Sorry Imma newbie at this and trying to understand. If left alone for a bit is this condition dangerous? Thanks again GF
2000 GL1500SE
Just FYI, it would be a good idea to pack those bearings with grease before installation. When they come to you they might not have much grease in there.
