83 interstate no parking lights
578 Views 4 Replies 3 Participants Last post by  trashtruck
I have a 83 gl1100 interstate that the parking lights quit working.
I have my markland bumpers with the marker lights hooked into the trailer plugs that are behind the license plate.
I had to jump start my bike a while back from my truck.
I only hooked it up long enough to get the bike going but it popped the brake light fuse anyway.
I replaced the fuse and my brake lights and the marker lights light up but when I turn the ignition to the parking setting I have nothing.
Can someone point me to the cause of this issue?
check all your fuses. parking, tail lamps are seperate fuses.
There is a separate fuse for the park light.
Can you tell me where this fuse is located?
The group of fuses under the faux tank are all good.
Thanks for the help guys.
fuse box should be labeled left to right: turn signal, engine, tail light, headlight, parking, acc. have you checked the bulbs? i've had vehicles where the socket gets old and the bulb vibrates loose and wont make contact.
