I've searched the topics, but I couldn't find any problems like I'm having. After the bike was parked for 5 days. I tried to start, and it just clicked a few times. I thought I would just give it a charge while I was at work. Hooked up the charger, and got no results. The charger showed no volts. I turned the key on, and the charger showed 4 volts. The bike volt gauge showed nothing. With the charger hooked up my light would come on dim. That afternoon I decided to give it a push. It tried to start a couple times then I got tired of pushing it. These wings aren't light! Went out this morning turned the key on and I have absolutly nothing. Like the battery isn't even hooked up.
Any suggesting would be greatly appreciated.
have u tested the battery? sounds like a bad battery to me im sure some of the gurus will have more ideas
Sounds like a dead battery. A "dead" battery will no longer accept a charge.
:waving:Sounds like the battery is defective. Take it to the shop and have it load tested and it will no doubt check bad.
I thought so, but wanted to see if there were any other bugs that may cause the problem because this was the first time the battery gave me any kind of trouble.
while your replacing the battery also replace the dog bone main fuse or install a blade type fuse and holder .
Got the battery yesterday. After your advise and using the search tool for topics; next week I will be installing the blade fuse and holder.
Thanks for the responses.
