1 - 2 of 2 Posts
sometimes on the old girl when using the turn signals they come on late sometimes 10 secs after hitting switch anyone ever have to to pull apart the sw. to clean the contacts or is there somewhere else i shouls look thanks also used the sea foam that was suggested here to clean the carbs out and worked great thanks for the info:waving:
If it still has the stock 3 pin flasher it can do that. Get an automotive 2 pin electronic flasher, leave the green wire disconnected and all will be well.
1 - 2 of 2 Posts
