Fellow Wingers, I was checking the air in my rear shocks last night and when I depressed the rear schrader air valve a bit some (oil?) came out? None came out of the front valve. My original air gauge did not work so using a spare gauge I checked the pressure to be around 14 lbs. Using a bicycle pump I put in 26 rear 20 front. Also is there a way to repair the original gauge? I tried WD40. Thanks guys!
