If you store it for several months during winter you need to either get a battery tender or remove the battery and keep it in a climate controlled room and charge it occasionally.
Get a copy of the service manual & check out your electrical system. Something's not right. Sounds like your system is either over charging or under charging.
durning times of lay up the battery will run down if you dont have a battery tender hooked up. or slow charge it 2 - 3 times a month . dont for get to check the fluid level and add only water. distilled perfferd .
