When i went to replace the headlight om my 83i, I removed the adjustment knob and the nut behind it.When i Pulled the light out out the spring for the adjustment knob and the nut for the adjustment knob fell out. I don't know if the PO had replaced it and had problems or not.
My question is, is there an easy way to put this back together or am I fighting a losing battle?
Other side of the pond
Do you mean the adjuster screw and spring? They should slot back into place very easily.
The adjustment knob behind the speedo has a nut on the backside..Is there an easy way to thread that back up?
Jad
Once you pull the knob off you have access to the nut and washer. There isn't a spring there on the locator bolt. I'm not sure where that spring came from.
The adjustment rod was loose and the nut had faalen of the back of it...once i got that figured out it went back together pretty easy...
