Hi all,
About to finally repaint my travel trunk on my 83I, and need to know what the lid is made of. Is it fiberglass or ABS? I need to know so I can fill some scratches (a few are a little deep), and I don't want the filler to crack after painting. I have liquid ABS on hand, so if it's ABS I'm set.
If it IS fiberglass, what can I use (in the states) to fill the scratches?
Thanks!
Jack
· Postpubescent member
It's ABS.
· Senior Guru
Jack, for finr scratces on plastic most repair shops use body filler anyway and it doesn't fall out. Plastic Padding do a flexible filler taht works well on plastic ans is easy to sand down.
