I would like some advice on issues that I have been having with my 84 1200 GW. Please bear with me as I explain the problem.
This problem has been plaguing me for a couple years now. The problem is that when I take the bike out for a ride sometimes I can ride for a hr. or so and nothing goes wrong. And other times I can ride for about 5 miles and I lose power and the bike dies. And I have to trailer it home.
To try to diagnose the problem I have run the bike in the garage for a long time. The bike would run for a long time. And I would run it at idle for a while and at 2k rpms for a while and 3k for a while and @ 4k for a while and it runs file. And up and down the rpm scale rapidly too. In neutral and also through the gears too. Of course I have it on the center stand and a fan blowing on the front of the engine so it doesn’t over heat.
Thinking it is fine I take it for a run on the street and not too long into the ride it dies. Sometimes it would start back up after it cooled down. And other time I would have to trailer it home.
Here is the history of the things that I have done in the order at which I have done the work to try to fix the issues over the last couple years.
I am losing my patients with this bike and I am now thinking that I have to rebuild the carbs. I am nervous about rebuilding the carbs because it is a big job and it’s been a long time since I have attempted that type of job. Never on 4 carbs before. I have all the tools to do it but I am just nervous about the outcome. I have been looking for a good rebuild kit and I have seen that Randakks has the best reputation for their kit. But they don’t have any in stock. I don’t want to buy a cheap kit. And I want a kit that can solve the ethanol gas issues.
So can anyone add to helping me fix my dilemma on solving my problem?
- Removed the stator plug and hard wired those wires and confirmed that they are ok.
- New voltage regulator.
- The bike is putting out any where’s from 11.5 -> 14v during the ride. I have a volt meter on the bike so I can see what it’s doing during the ride.
- Replaced the fuel filter and fuel lines. The lines were leaking.
- Replace the pulse generator plug with a modern water tight plug.
- This year I replaced the fuel pump and fuel pump relay. I think bench tested it wrong and I messed up that system so I replaced both of them.
- This year I replaced the pulse generator w/a new old stock unit.
