I am trying to remove the old bearings on my 84 ASP. My bearing remover tool is the type you slide in, the tongs open up and grip the inside face of the bearing and you pull it out.
My problem is there is a sleeve runnning thru the rear hub the exact same size as the bearing inner race, so there is nothing to grip to pull it out. I cannot even tap it out from the opposite side as there is no lip to tap on.
If I bring this to the local dealer, I'm sure they will tell me to replace the wheel. The wheel is true, and even the bushings are excellent!
Any help/suggestions would be greatly appreciated.
As always
Grant
As always
Grant
