The speedometer has been intermittent on my Aspencade for most of last summer. I've been doing a lot of reading. Many posts point to a possible faulty speed sensor. I took it apart. Apparently it's been a problem before, as this one has already been epoxied up, and the screws have been partially stripped....someone's been in here before. I've had troubles with leaking forks (solved now), and the sensor was drenched in fork oil. That probably contributed to the failure. Still....could it be the speedometer unit itself? Most other things light up, as does the tachometer.
Extra credit: I've read about doing the repair by replacing the hall effect sensor in the sensor itself. I've also read that some Valkyrie sensors can serve as a replacement with a minor modification. What suggestions do you have?
Much appreciated!
- I've verified that the gear unit on the hub turns as it should
- I pulled the sensor, and tested it with a drill. Nothing on the speedo.
(Yes, the key was on. Yes, I tried both directions.)
Much appreciated!
