Not quite but only 1/2" according to the specs, but it might not balance well, you may need a little room to play with and with the chock in, that might push it back a little further. I built a 4x9 for mine.
A stock 5x10 would be better.
I use a 4x8 trailer with the chock and it does tend to put the weight further back with the chock installed. Main thing is axle location as mine is pretty much centered to the bed. If the axle is further toward the rear then you shouldn't have much problem. Soon I'll have a winch mount with battery mount welded to the tongue so the weight will center more back to the front. I also plan to offset more weight by adding a tongue jack.
Does this trailer have a gate or fold up ramp on the back? If it does then it won't go all the way up with a bike that has a trailer hitch install, at least as far as the 1100's go.
The 5x10 would be much better as it will handle just about any bike including most trikes.
Im going to stay away from the gate trailers. Angle on the ramp looks to steep. Im looking at a marine grade flat wood deck 5x10 tandem trailer. I plan on using 4x7 aluminum folding ramps for loading/unloading. The ramps will have locking dowels, so I have any surprises. Just waiting for the $$ to make this happen.
I might look into doing that for mine but if I do it will put the chock right over the tilt lock.I made a 4 x 8 trailer with a cut out in the front & mounted the tire chock on the tongue, this allows the weight forward & the tailgate to close. :waving:
You just caught us after christmas when we're in good humour, just wait till you ask an oil related question....:shock:Thx for your help guys. I cant believe how helpfull you members are. I have belonged to 7-8 diffrent boards, with regards to the misc vehicles I have owned. This board by far is the kindest and most helpfull..
