i rebuilt the 84 GL starter 2 months ago, now same thing CLICK and volt meter goes WAY DOWN with new battery. it rained just a little, bike had a cover on it went to start it and POP went something electrical and ... same as before. push the starter button and volt meter goes to 8.x when it started out with 12.7. new battery 2 months ago.
i want a new starter, i want a lot of things... but ... is there something IN THE ENGINE that will stop the starter from doing anything... like starter chain and related assembly doing something "funny" and locking the motor up?
when i rebuilt the starter, it was pretty clean, brushes were good, i didn't replace them. it did work fine... for 15x or so that i have ridden the bike since, but now, nothing. is it a starter issue or something deeper and more sinister IN the motor? i read about something like that... starter chain/clutch ... i forget the rest. last time i even jumped the starter, straight to the starter lug, with a good battery and just sparks, starter would not turn... so took apart starter to clean it/oil it etc. so????
new starter? im sure if i take the starter out and put it to a battery it will spin with authority, but with no load, that means little. i really do not want to spend BIG MONEY on a new starter, $65 on e bay for new starter... for 85/-87... that does not work on 84? and then used 84 starter that... i suppose works for ... a while? i just dont want to do this too many more times as finagling the starter out is a 20 min deal...if a person is lucky and the same going in. when spend more time and money on something than using it... it gets tiresome and a person wants to ... give up. shdve spend more money on a NICER BIKE, but dont have the $ now to do much of anything but band aid things best i can
Try turning the engine manually, it is not the starter chain or clutch causing the problem. Sounds to me like you have a bad connection to the battery, a bad cable maybe. Or could be the new battery is bad, it happens. If you take the voltage directly at the battery when trying to start what do you get? Do voltage drop tests. Connect one lead of the meter to the + terminal, the other to the starter terminal, check voltage. 1 lead to the - battery terminal, the other to the engine block, check voltage. There should be less than 1v in either of those tests, get back to us if there is more.
well... that is a thought.... hydro locked from leaking carb float needle? lets hope not, can bend connecting rods that way. turn off fuel and pull plugs? and check the battery voltage... cld be a bad battery? it worked fine for the whole month i have had the bike running. i have extra car battery and jumper cables to go straight to the starter and see if it will turn... after i take the plugs out and see if got gas in the cylinder/s.
when i engage the starter, it really pulls that battery DOWN... to ... 9.x like a direct short???? the attached volt meter is taken from the +/- of the battery, hardwired permanently to the bike since they have known stator issues so i need to know if/when the stator is going out
how to turn the motor manually. i wud roll it down the short driveway and pop the clutch... but if it doesnt start... i cldnt be able to push it back up the driveway and here... not a good thing to Leave ANYTHING outside, especially in/near the street as things disappear overnight here. hardware store locks are not worth throwing out.... here.
