So my 84 GL1200 suddenly started running rough like not on all cylinders. Since it is an old bike that I recently re-acquired and it showed some signs of neglect I decided to overhaul ignition and fuel systems.
I replaced both coils, all 4 plug wires and spark plugs with new OEM parts.
Then I pulled the carbs, inspected and cleaned everything I could. There were a couple of gummed up float bowl screens that could have starved their respective cylinders of fuel. I replaced fuel lines, filter and new fuel pump.
After reassembly, synchronizing and drop down setting of pilot screwsI (landed at 3 1/2 turns out), took it out and it ran so good I was grinning like an opossum eating bumble bees. On the way back as I was congratulating myself on the success of all that work about a mile from home it started running rough again. I pulled the plugs and they looked a bit lean so I backed the pilots out another 1/4 turn. Made no difference. It hesitates and sometimes backfires on acceleration.
I can smooth it out while riding by giving it a little choke. Since the choke makes the mixture richer, I wonder if I need larger main jets. It is a CA bike which leads me to also suspect the SAS. I did replace all vacuum lines while the carbs were out.
Any help here would be appreciated.
Meanwhile I am rocking Seafoam in the tank as a desperation shot.
