While cruising today, my clutch lever fell off. I retrieved that, but noticed that the master cylinder for the clutch seemed to have lost some pieces. I prodded inside and found a small rubber boot, two springs, and what looked like the end of a small piston. I figure that I am missed the end bolt that goes through the clutch lever handle, and the small rod that should make contact with the small piston, protrude through the boot past the two small springs and thereby push down on that piston. Am I about right on what parts I need. The master cylinder seems to be impregnable and the only access seems to be through the cylinder that houses the parts-am I right about this?:X
