What would cause my clutch to not disengage? When i have the clutch handle pressed in it still wants to take off. I didnt seem to feel the clutch slip. The handle seems to be loose also.
You need to bleed the clutch hydraulic system. It could have a leak but you will have to get the system filled to know if it does or not.
1987 GL1200 Interstate
Yeah, probably just adding some fluid will get you back on the road, however, this is a sign the system needs a complete service. I suspect you'll find a leak at the slave. If you don't see a leak, then probably into the engine.
Also as mentioned, the pivot can be worn out.
Anyway, welcome to the forum.
Check fluid level and position the handle high as it will go and work the lever to get air bubbles back to the reservoir. You may have a slave cylinder leak.
