Greeting: Has anyone found a way to patch holes in a goldwing plastic trunk. I have one with nearly two hundred holes drilled in it. thankyou very much in advance. Ron
:waving::waving:Welcome to the Best Goldwing Site on the Net, oldbikerguy!:waving::waving:
Your handle is almost redundant on a Goldwing site although we do have some young'uns here. There are several methods that would work for you. One way is to clean and sand off the area inside the trunk and put a blob of Marine Tex epoxy filler over the hole and sand it flush on the outside. Marine Tex is very tenacious and sticks well to ABS. Another way would be to cut some narrow strips from a piece of ABS pipe and weld the holes with a soldering iron. The Clymer Manual has a section on this method. I would not use polyester resin, the more common fiberglass resin, it doesn't properly bond to plastics like ABS.
