totally confused on this one, I have an 85 1200 interstate, when i went to work on monday it was charging at 14.2 v(according to voltmeter installed on dash) went to leave work started good and ran good but voltmeter would only read 11.7 volts, 50 mile trip to get home checked voltage on battery 13.6 volts???? used 4 different meters in case of inaccuracy all said same thing, thought must be bad voltmer on dash, checked it reads correctly with a spare fully charged battery, decided to do stator test, no continuity to ground from 3 legs, checked volt ac volts, only puts out 37 volts at 3000 rpm, again tried four meters, all read close to same 1 read 35.5v, put meter on battery ran to 3000 reads 11.9v - 12.1, have been riding for the 2 days now waiting on new stator, each time i get to work or home put it on charger, but battery is at 13.6 volts so it wont charge. have tried spare battery same thing happens, battery in bike wet cell is 1 1/2 months old, spare is glass mat about 2 weeks old. how can i have 13.6 volts when only putting in 12 or less. have had since march and PO said new stator in january( after the other problems found on bike i dont believe him alot of things not done right)
thanks for any help, help i dont confuse anybody
