1 - 3 of 3 Posts
Just cleaned my carbs and when I put them back in the fuel pump won't run. It is a pulse type pump can it be jump with 12 volts or will it fry it, the pump is a electro magnet with a bellows that causes a pulse. It wont make a sound when the bike is running I fill the carbs by adding fuel through the fuel line on the discharge side with a large syringe and the bike runs but the pump does not put out any fuel at all.
I took the pump off and touched the leads with power proper + and - conections nothing should it click like a celeniod on a ford truck.
any ideas on this hard to get parts way out in the Atlantic
thanks guys
on your bike any cheap aftermarket fuel pump will work
The fuel pump will only operate while the engine is running. I don't know about direct wiring it. I got my replacement used thru E Bay i think i got it for $60 including the relay. My pump will make a clicking sound when it cannot pump fuel as when i turn off the petcock when i'm putting her away.
Good Luck Jim
1 - 3 of 3 Posts
