1 - 12 of 12 Posts
My GW has 30K miles. I have a small oil drip from bottom of engine. Has this been common and is it a major fix? Any suggestions?
You will have to tell us where the leak appears to be coming from, ie is it the sump plug, filter housing, geareshift seal, waterpump...
Dhorn, welcome. Your going to have to be a lot more specific about an oil leak. It could be as minor as the washer around the oil drain plug, or as major as a crack in the engine cases. Best advice I can give is to thoroughly clean the entire bike and engine and try to see where the drip is coming from. That's it for now
Thanks for your reply. I will do that and get back to you.
Senior Guru
Have a good look around the edges of the valve covers and look closely at the shifter seal. You cannot simply tighten the valve covers because they have bolts with stops built in so you'll need new gaskets. If it's the shifter seal leaking it is best if you remove the exhaust manifold so you can drive a new seal in square.
Vic
I cleaned the engine real good and it looks like there is a drip right along what looks like the valve cover gasket. Have you ever replaced this. It's a small leak but oil leaks drive me crazy.
Dan
It's an easy job, get the new gasket, you may want to get the gaskets for the valve cover bolts as well, they're all rubber seals. While you're at the Honda shop, get a tube of "Honda Silicone" put a little dab of silicone on the new gaskets on the 4 points.
This should stop early leaks on the new gaskets.
Senior Guru
Dan
You will need to remove the fasteners on the crash bar at the frame downtube and loosen the lower nut on the bottom arm of the crashbar to remove the valve cover.
Make sure you clean the gasket surfaces carefully and try not to let any of the old gasket pieces fall into the engine.
As Tony stated use a minimal amout of RTV silicone to seal things up a bit better, but don't use too much silicone because it can come off and cause oiling problems.
This is not a difficult job, but pay attention to keeping dirt out of the engine.
Vic
Discussion Starter #11
Thanks very much for the info. I will dig in and give it a try. And yes, Ham Lake MN.
1 - 12 of 12 Posts
