All,
The 85 GL1200I project I'm working on is going to need the pulse generator sensors replaced . When the starter solenoid shorted it took out the main wiring harness, starter solenoid, pulse generator wires.
Just to make sure I'm referring to the correct part, its located front right side, behind the timing belt heat shield, and just behind ( looking from the side) the right front exhaust pipe .
Looking at a down loaded Haynes manual, I don't see a actual section on the removal and replacement of the pulse generator sensors. Is this a engine in replacement ? Does anyone have a procedure Doc for this , thanks.
enjoy,
All,
enjoy,
Sensitive content, not recommended for those under 1866.2 KB Views: 57
