I see you have an LTD. Prepare for charging system problems. I won't get into all the details right now, but I consider it a design problem, and so do a couple of professional mechanics I know.
There are things you can do to minimize problems, and one of them is to eliminate all plastic connectors that show the least bit of heat damage. The first one is in front of the battery, and has 3 yellow wires going into and coming out of it. These are the main wires from the stator. Check it. If it is the least bit burned, cut it out and solder the wires together. You will need to splice in some extra wire to make up for the missing connector. Make sure it is the same size or bigger than the yellow wires.
Now remove the fake tank (yes it involves a bit of work, but it needs to be done) and check the TWO white plastic connectors on the regulator. The regulator is on the left side of the frame, just in front of the cruise control unit (the flat round thing with a throttle cable going into and out of it). The regulator is a small metal box with fins on it. There will be 2 connectors. One of them will be just 2 yellow wires. These are 2 of the same yellow wires that were down by the battery, that come from the stator. The other connector will be larger, and has the other yellow wire, 2 green wires, 2 red/white wires, and one black wire. Check both these connectors thoroughly, take them apart and check inside if there is no obvious outside damage. Remember thats three connectors altogether, one by the battery, and 2 at the regulator. If by some strange chance any of them are not burned at all, pack them with dielectric grease and put them back together. But I have yet to hear of one that has survived for 26 years undamaged. Again, if they are burned, cut them out and solder the wires directly together.
Remove the regulator and make sure the mounting surface is not corroded or dirty or rusty. The regulator needs a good ground.
Those "dogbone" fuses actually work pretty well, but they are subject to corrosion, which causes high resistance and heat, which burns them into. The problem is you can't get them just anywhere. I recommend cutting out the entire fuse holder, and soldering in an automotive fuse holder big enough for a 30 amp fuse, and using the 2 prong automotive 30 amp fuses. Carry a few, just in case.
Even when done this way, the regulator is going to run HOT, I mean REALLY HOT. To find out just how hot, start up the engine and let it run for about 10 minutes, before reinstalling the fake gas tank. Then tough the regulator with the tip of your fingers. Be careful not to get burned. I had a blister on my arm where I accidentally touched it. It gets hot enough to burn the insulation off wires, so make sure no wires actually touch the outside of it. Tie them out of the way if necessary.
After I get some other issues with my 1200LTD squared away, I am going to go back to the charging system, and see what I can do to make it run a bit cooler.
