1 - 3 of 3 Posts
My '85 Ltd 1200 started to idle at low rpms all of a sudden. Upon start-up will idle at somewhere between 950-1100 rpm. Aftre running for awhile, then will drop to 750 - even has a tendancy to stall upon occassion.
Any ideas. Gas filter? Fuel injectors? I just filled up with some premium gas to see if that makes a difference.
sounds like a vacuum leak maybe. Mine idles between 800 and 900, sometimes drops to 750, but usually picks back up and never stalls.
Not up with the LTD but suggest changing the fuel filter and then run some fuel injector cleaner through it .
If it hauls ok at high speed then fuel pump is probably ok.
If you have no fault indicators , run the cleaner for the next 2 or 3 tankfulls .
1 - 3 of 3 Posts
