Do not use a 12 VDC 3 ended plug. The "IG" terminal needs 12 VDC as does the "S" terminal. The "S" terminal is needed too so that the internal RR can adjust the power output to match the electrical system requirement.
I would not put 12 VDC directly to the "L" terminal. This is a ground terminal used with an indicator light. When used, the 12 VDC power goes to the indicator light, then from the indicator light to the "L" terminal. When you first turn the key on with an indicator light installed the light will be on. When you start the engine and the alternator starts producing power, the indicator light will go off.
As mentioned in my previous post, take a wire from the battery positive terminal to the alternator "IG" terminal, this can be split and connected to the "S" terminal as well. Take the old sense wire from the RR - black in colour - and connect this wire to the "S" terminal. This black wire is at the end of this wire circuit and comes directly from the ignition switch so it will indicate what the electrical system voltage is and the alternator will compensate accordingly. It's better sometimes to remove what is there and install new.
The alternator will work with only the "IG" terminal connected to 12 VDC, but will not work properly - BTDT. This alternator needs to have the "S" terminal connected, otherwise the alternator internal RR has no reference for the power output, in other words it's a crap shoot what you get.
Good luck
Good luck
