Probably taxing the engine, creating a lot of heat, which is detrimental to anything ignition related, such as the pulse generators, although if that were the case, seems that it would be 2 cylinders....
Maybe a fragil plug wire, or a cracked spark plug porcelin.... Sounds like something is grounding out, or breaking contact.... Maybe just a dirty gound wire, which when stressed, is failing, but that ostensibly would be all 4 acting up.....
This is from a layman though, so hopefully those with more knowledge will check in...
