After replacing my head gasket and puting everything back together I noticed oil leaking really bad around the pulse generator seal. So I ordered a new seal to replace the old one. It still leaks but not as bad :X. The leak is coming from inside around the shaft. It looks like I may have to order another seal or maybe two. There doesnt seem much I can do but insert the seal by carefully taping around the edges till it is flush inside the case or tap in in with a socket of the same size. Could there be something else wrong as to way the new seal leaked or is there a trick to put in in?
