have an 86 i that I bought in the spring. previous owner stated he had issues with it running, so he had pulled the carbs 4 times and cleaned the main jet. i pulled and rebuilt the carbs. i also installed the electrical connections wire harness to remove the two connections in the stator wires. now i am unable to get fuel to pump. there is fuel in the filter, but the pump doesn't run. i have a second 86 and have tried both pumps and relays, but no luck.
Is it getting spark? No spark no fuel pump. If it is getting spark it could be the fuel pump relay. Have you tried wiring the pump direct to power?
1987 GL1200 Interstate
Geez Weiss. You've only been a member for 9 years and already you've made a second post...?
What an internet hog. .. :devilish:
Anyway, welcome back.
