1 - 15 of 15 Posts
Discussion Starter #1 (Edited)
Good evening gents.
Ive recently done quite a bit of maintenance on the ol girl and she was down for at least 6 months while I was working. When I put her back on the road she feels unstable at speeds over 70 mph. No vibrations, just weaving back and forth no matter the wind. I can incite the weave at around 60-65 by dodging a pothole move.
MX performed:
Front tire leak (around the rim) fixed.
Rear tire (same brand as before) replaced.
Rear brake rotor replaced.
Grips replace with Kuryken (or however you spell them).
Head bearings retorqued (replaced last year with AllBalls).
Ive double checked the rear axle install, the torque on all the triple tree hardware and front wheel hardware.
This same weaving was felt before all of this before but only in high speed turns. This bike has 115k miles and well taken care of. Everything still works on it except a few ligh bulbs I dont know how to get to.
Im running same pressures in the tires and suspension as before.
How much pressure are you running in the tires? If not at the maximum from the sidewall of the tire try adding some more pressure.
41 if I recall. I’ll recheck and bump it up a little. I wonder if I put too much torque on the head bearings...?
Swing arm issue? Frame rusted out near the bearings or loose bearing? If you ride straight through a puddle of water do you leave a single line behind you or a double line? Tracking straight.
I tried to move it by hand on the center stand. Maybe need to replace those bearings as well. I don’t know the correct procedure for checking looseness except for applying pressure while unloaded. I’m fairly certain it tracks in line.
Could be as simple as an over-torqued steering head bearing. Though those usually show up at lower speeds, too.
I’ll loosen the bearings and try again. Before and after I change the head bearings at around 40 mph (maybe lower) if I hit a bump with a loose hand grip, the front shimmies fairly aggressive. Not above 55 though.
I didn't see fork oil on your maintenance list.
Follow the Honda shop manual for setting the head bearings. It's kind of a pain but works!
2012 GL1800
I had the same problem on my 2004 after I installed the All Balls. Loosened them up a bit and every returned to normal. I found the tapered bearings don't need as much torque as the OEM's
Discussion Starter #12
That’s good to know. I’ll try that first.
I’ve the bike on the center stand now and I find no side play on the swing-arm. Maybe I can find a guy here in Houston that is good at these 1200’s and let them inspect it.
1 - 15 of 15 Posts
