1 - 3 of 3 Posts
I have a mute problem as well with my wing, the mute will activate when i hit a bump, but not allways, then a lot of times if i cycle back and forth between hi and low beam and the mut will go off, allways some thing electrical , ie rear brake , turn signal , horn. would like to know where radio gets its ground , i have the manuals , but im not too good withreading the shematics, ant thoughts?????
Jamie
Other side of the pond
It sounds like you have a loose connection somewhere Jamie. Have you had the radio console off recently?
Just another ORF!
Sounds more like a loose/dirty connection(s) in your left handlebar switch housing to me. :?
1 - 3 of 3 Posts
