1 - 17 of 17 Posts
Bike starts right up put it in reverse press starter switch bike dies right away. Then a slight surge backwards just enough to notice. Take it out of reverse and it fires right up with a slight delay to reset.
Best guess were to start?
Thx
Just to be sure, you are saying the engine shuts down when you try to use reverse????
Is the sidestand switch working properly? That is you have driven the bike since this issue ?
Does the neutral light work properly?
Does the reverse light come on when you are in reverse and teady to push the button?
Yes everything works properly just when I hit reverse it dies and all dash lights go out. Reset the key and it will restart. Doing it a few times and reverse will work sometimes
I'm inclined to think you have a bad or loose battery connection.
  • Like
Reactions: redwing52
Hey Dave how ya been long time no see.
Thx will check it my first thought was the dog bone or relay but all those checked out.
I've been doing OK mostly. Where & how have you been?
It aint rocket science
I would be snooping around relays 3&8*
  • Like
02 GL1800 w/Auto Pilot
I have a manual for the '89, or at least '89 is the date on the manual.
if that is good enough, let me know who wants it and I will send it by WeTranser
I would like to have a copy if you would.
Thanks, Mike
Thx
Does your Fuel and Temperature gauges work...?
If so, no need to snoop around the # 3 and # 8 relays.
If no battery connection issues, check the Red 4-pin plug under the seat (at the front edge of the trunk). It might be loose or disconnected....!!.
If you follow the diagram posted by Erdeniz the reverse/start system uses fuses 2,8,11 and relays 3(main) and 8(ignition/cruise). Since you have an intermittent problem one can reasonably conclude there is not a fuse problem. Relay 3 as the main is usually the one to give trouble and should always be checked for hot/melted terminals while in the neighborhood. If the reverse were tripping the No.8 relay to drop out that would kill the ignition and the bike would stall. Try swapping the 8 relay with one of the ones to the left and see if problem persists.:)
Are you a big user of reverse and when the bike stalls does the CRUISE ON light also go out assuming you leave it pushed on?
Discussion Starter #15
Found the problem a broken plastic cover on relay. Split at the post to where it thins out to make the cover. Moves just enough not to make contact or moisture not sure evidence of both.
Replaced works fine now.
Thx for your help all
Happy trails
Thx
It could be the speed limiter kicking in. From the service manual:
When the speed limiter is activated during reverse running, followed by the electrical motor brake, (when the motor is overloaded more than three seconds), the reverse system is turned OFF and the reverse indicator goes out. To use reverse again, it is necessary to return the reverse lever to the OFF position and then return it to the ON position.
Inspect the following before troubleshooting the reverse system:
  • Be sure the transmission gear is in neutral position.
  • Be sure the reverse lever is in the ON position and reverse cable is properly adjusted.
  • Be sure the side stand is up.
  • Be sure the following fuses are good: fuse 5A - the left side of the battery reverse fuse 65A - under the seat.
Also from the service manual:
Reverse stops troubleshootingReverse stops troubleshooting
Reverse connector locationReverse connector location
Reverse connector diagnosticsReverse connector diagnostics
The reverse diagnostic procedure is a bit big to post here (it's over 30 pages long). This could at least give you a start of where to look.
If you check post #15 you should see the problem is fixed and was a bad relay. Welcome to the forum just the same though. :)
1 - 17 of 17 Posts
