88 carb swap
605 Views 5 Replies 3 Participants Last post by  Jim P
I have a 88 1500 with the common hesitation problem. I decided to switch carbs after reading some posts in the index. I got 99 carbs that are in good shape, the problem is with the throttle cable bracket. The 88 bracket won't fit on the 99s due to the different position of the bowl vent elbow-- If I hook the cables to the bracket on the 99s-- the cables have too much free play. The bottom cable doesn't seem to be adjustable at the bracket - The upper cable is adjusted all the way back with still too much freeplay. I am not concerned with retaining the cruise cancel micro switch but the distance between the outer cable ends and the throttle drum-- The distance is longer on the 88 carbs. Wonder if any one that has done the swap has a solution???
Hi jim i take it you know the trottle ajustment is at the trottle hand grip its self not at the carbs might just get enough there
Hi Peter - Yes I did adjust at the throttle grip - not enough adjustment to set freeplay
How about removeing the spuds on the end of the cables and refitting to suit
I put '95 carbs on my '88, and had the same problem. There is not enough adjustment, even if you "lengthen" the cables as far as they will go at both ends.
I "cheated" the return cable a bit with a homemade spacer, and still have a little freeplay in the grip at closed throttle.
I checked operation in both directions, and there's not enough slackto cause a jam or hang-up anywhere, andI can still crank 'em closed if I have to- so I'm just living with it.
I may try a spacer in the return cable and see how it works - I can still return to the 88 carbs if I don't modify the cables.
Jim
