I just rebuilt my carbs & I want to fill the carbs to make sure they are not leaking etc. I have not put the air cleaner lower section on yet. Anyway, I turned the key on & the fuel pump runs for about 2 seconds & shuts off, no fuel thru the fuel filter. I'm thinking that since I don't have vacumn on the auto fuel shut off valve on top of the tank that may be my problem. I was thinking about hooking my mighty vac up to the line & giving it some vacumn. Should this work or is there something else I need to do before the fuel gets to the carbs?
Yes mighty vac to the petcock will do the trick or you can turn the key on and off a few times too.
Anti-Guru
Seems like a lot of tooling, but yeah, a MightyVac will work 5-7inHg should open a used petcock, all petcocks sould be open by 11inHg and they should all tollerate max... If your Mighty Vac isn't handy, you can just suck on a bit of hose to supply the petcock with enough vacuum to alow fuel to pass during your '88's key-on prime...
