hi has anybody accidently touched the frame of their bike while removing the batterie which caused the start button not to work like i did i still cant fix it ,it is prob something easy for some of you but not for me lol all fuses relays are ok i can bypass it to get bike to run but i need to know wat and were the prob is if any one can help it would be most grateful cheers dave:bow:
Senior Guru
Hi Dave under the rubber booth on the starter relay to the right of the battery is a 30amp fuse have you checked this also dont take any fuses as sight seen you need to test them
ok m8y ile double check how do i test it please i have an ordinary circuit tester which i can use to see if there is power
Senior Guru
If you have the tester with the bulb in it you need to earth the wire on it to the bike then turn on the ignition and test both sides of the fuses the tester should light up on both sides if only one side the fuse is gone the problem with the blade fuses is it may be cracked and not burnt so you wont see it
