1 - 3 of 3 Posts
:praying: Does anyone know how to eliminate the alternator from the motor? I have developed a alternator noise and have been told it could be in the alt. or motor. Can I remove the alt. and then start the motor?
Thanks Peter:ssshh:
Honda Guru
Yes…. you can remove the alternator and start the engine BUT you'll get an oil spray all over the place.
Find a way to block off the hole where the alternator goes and be sure to remove the rubber dampers and you should be ok.
Obviously this should be for 'diagnosis only'. The alternator bearing does has a history of going out.
1 - 3 of 3 Posts
