:waving:Hello to all the GREAT GOLWING GODS, I BOW to You:bow: Please help me with this problem. I cant open the trunk. :stumped:Turn the key to unlock . Pull the center lever but does not UN latch.:? Saddle bags work perfect. Is there away to open it with out Damaging it. I hope my Question is worthy :bow:
You might try hitting the top of the trunk with the palm of your hand while keeping some pressure on the latch.
Anti-Guru
studiobill001 wrote:
:jumper:Thank you For all your Knowledge. And a link to the thread. It worked:claps:
:readit:I see TWO great things here:
#1- You're in and able to repair whtever had failed.
#2 - It's your knowledge now. Ride safe and share it...
Glad you got it open.
As a preventative measure, add a Zip tie to horizontal bar, and extending it out slightly from below (where the activation levers are)... That way, the next time it's stuck, you can reach up and pull the zip tie to open the trunk.
