Back in May, I became the proud owner of a 1989 GL1500 with less than 25,000km. I soon learned that I was also the owner of a hesitation problem that the early 1500's are famous for.
The problem wasn't so serious that I couldn't ride the bike. It just let me down a couple of times when I needed power and didn't get it. I learned to aviod the flat spot and rode it all year. Meanwhile, researching the archives of this wonderful forum, I learned that I was not the only one to experience this. Two possible solutions appeared. One was to replace the slow jets and the second was to advance the timing by installing a 4° trigger wheel.
The jetting solution seemed to make the most sense to me, based on what I was experiencing with the bike.
I bought a couple of #60 jets from PJ Motorsports $7.00 each ($27 delivered)
http://www.pjmotorsports.com/
I finally got around to installing them. Pulling the plastic off the bike was perhaps the hardest part.
While I was in there I took a look at the sub-filter. The foam crumbled when I opened it. Made a new one from a foam paint brush (thank you Mr. Dusty Boots).
Again, thanks to this forum for the links and info on how to pull my carbs apart. I would never have attempted it without knowing that this forum would help me if I got into a jam.
Today, I got her all back together and took her for a test ride. What a difference! Hesitation gone. I could not make the bike stumble no matter howI tried.
