I have a 89 GL1500 with a strange turn signal issue. All was doing fine as usual and then the turn signals both quit working and I noticed that the hazards are not working either. I checked the relays under the trunk and the one for the turn signals was a bit loose. I pushed the connector in and heard a click and then they started to work ... Thought all was done. The hazards still are not working so I swapped the 2 relays and the same problem is there. The hazards do not work but the turn signals do. Ok so I know that the relay is not the problem. A week later the left turn signal quit working but the right side works fine. I went back to the relays and that is not the problem. I do not know where the flasher is how ever. Any ideas?
