have 1988 goldwing will the 90 amp compfire altenatorwork on my bike and will any changes be neede
Other side of the pond
I don't think they "officially" fit into the 1988.
I'm running one in my '88 - no problems.
(but, I'm no Guru . . . . ) :)
Anti-Guru
About the only "change" is the mounting bolts -- you can run the Compufire as is and use "normal" ('90 & after) mounting bolts, or you can drill the Compufire mounting holes to accept the larger diameter collars on your 1988 alternator mounting bolts.
They will fit the 88 as long as it's not triked.
