I checked the fuses by the battery. No luck. These have the chrome covers with the 4 switches over the clutch resivoir. Thanks. David
Being the original owner probly installed them. I would say somewhere around the steering neck. My bike has a aftermarket switch control and it has inline fuses and they are just to the right side of steering bearing.
That logical. Ill check it tomorrow. Thanks. David
mr irrelevant
You might look down in one of the pockets of fairing too or under them, PO may have installed extra fuse block in there somewhere....
You need to trace or find where the hot wire is going you if take the cap off the switch then see what color the weir is on mine all the wires are under the key switch cover then wired in to relays under faring pockets. hope that helps
Got it. It war a broken how wire right under the left handlegar. Thanks! David
