Does anybody know if its possible to wire a '91 GL1500 audio system so you can input a GPS unit's audio ?
You could use an FM modulator or a cassette adapter but the best way to do it is to add an aux input as many of us have done... Sierra will do it for you for a hundred bucks (link 2) or you can do it yourself for considerably less if you have the electronic skill set required (link 3)... This type of aux input can be routed thru speakers or headsets... With this type of aux input, you have to use either the aux input or listen to your AM/FM radio - both will not work at the same time...If your GPS also has a MP3 player and/or XM radio (Garmin Zumo 665) that will also play thru the aux input...
There is another device that plays thru the intercom only - here is that link (link 1)...
http://goldwingdocs.com/Store/Goldwing-GPS-Audio-Input.asp
The 2 links below are for the aux input mod to your radio
http://www.sierra-mc.com/gl1500auxinput.html
http://www.sheriart.net/honda/
Les
Well said Les. You've covered it completely.
Thanks Stu ;)
Les
Thanks for the links for that $60 device , I think I'll go with that. Some others in my GWRRA Chapter will want this also. Again thanks
