91 wing neutral lite won't lite when hot ,wont start w/o lite
Really need more information.
What model bike? Good idea to place your bike info inyour profile signature so everyone knows when you post.
Will the bike start with the clutch lever pulled, it should?
Is everything else working correctly?
If the bike won't start with the clutch pulled and the neutral light out, then could be Engine Stop Switch dirty, Reverse Relay not working, Reverse Switch dirty, or maybe, but doubtful,inline diode almost out.
My '89 may be different from your '91. On my 1989 GL 1500 the Gearshift sensor is located on the right front of engine, above the oil filter. The connector for it is a 6 pin black connector located behind the right marker light.
