1 - 3 of 3 Posts
I HAVE A 93 1500SE THAT RUNS WELL EVERYTHING IS SMOOTH EXCEPT FOR IDLE IS ROUGH AND GAS MILEAGE IS TERRIBLE JUST CHANGED FUEL & AIR FILTERS BUT NO CHANGE ANY IDEAS
Senior Guru
hi 93 there can be a number of factors causing your prob did you sync the carbs when you changed the filters, also have you checked for vacuume leaks or run any carb cleaner through the system some of the guys have found that if you ajust the trottle ajuster up and down a few times that the idle evens out and last any smell of gas when the bike is warm or draging brakes
HI AGNOGEL,
ACTUALLY I HAVE A MECHANIC DOING ALL THE WORK BUT SOMETIMES EVEN THE BEST MISS THINGS. I WAS CONSIDERING HAVING CARBS REBUILT THEY ARE GUNKY AND THE THROTTLE ADJUSTER WONT MOVE.
HE HAS MENTIONED ABOUT POSSIBLE VACCUM LEAKS AND SOME ELECTRICAL COMPONENT ISSUES BUT YOU GUYS ARE GREAT WITH DO IT YOURSELF ISSUES THANKS FOR RESPONDING
1 - 3 of 3 Posts
