Hi, re. my '93 project.... (it is now clear it has had a bit of an "incident" on the right side in it's past life) ...I could really use an image or two of the correct positioning of a couple of parts on my bike. 1) The rear "crash" guard position,.. as the right side touches the saddlebag, whereas the left has a couple of centimeters between it and the s/bag. 2) The "deflectors" on both sides of the lower fairing are not possible to fit as the engine guards seem to be too close to the fairing to allow installation.....I do understand the design of the front guards were changed at some point after 1993, but mine cover the entire rocker cover. If you could post any of images of these two areas from a "good" bike,it would be really appreciated, then I can do the work necessary to make these bits fit correctly..!!!
Many thanks................;)
Hi groutby. Not sure exactly what you need but here are some pics from my 94 1500SE. It has the same bars as yours.
Brilliant..!! thank you, that will be a great help.
Many thanks, :smiler:
