The (ECM)Engine Control Unit is on the right side of the bike, adjacent to the airbox... It's a black plastic box, aprox 1.5" x 4" x 5".
Try:
-Tighten the hose clamps to the rubber isolators, that connect the carbs to the intake manifold.
-Verify the vacuum connection is intact, between the ECM and the left intake manifold... That line (having a 90-deg bend at the manifold) controls the vacuum advance, and will mess up the idle if leaking.
-Cleaning the connector to the ECM
If that does not work, then check for a vacuum leak inside the ECM:
http://www.goldwingfacts.com/forums...orum/385647-gl1500-terrible-idle-surge-3.html
