Looking for help/Suggestions/directions on a 93 Goldwing. Purchased this bike recently which had been sitting for two years. Told there was a neutral switch problem.
Got it home......Put a battery on it.
While going over the bike, found a mouse nest on top of the block, below the air filter.
Cleaned this out, inspect the wires, everything looked intact.
Managed to get the neutral switch light on
Lots of spark while cranking....no fire
Opened it up to treat carbs with cleaner......found fuel pump not working
Managed to redirect power to fuel pump and get it working.
Carb cleaner worked and she fired up and ran.
Told tank was empty and that the seller had put 91 in it to fire it up (no luck on his part).
To be certain, drained the tank, added 91 and seafoam.
Solenoid replaced, timing belts replaced, new battery installed, oil change
Put her back together and nothing happened when hitting the starter.
Played with reverse, clutch, etc. starter would not kick in....
Tore it apart again to check wires, everything seems fine......
Radio has power, accessories work (Horn lights, emergency flashers, clock). however it will not turn over.
Tried playing with the reverse switch, used deep clean
Checked all fuses, including 30 amp, dogbone, relay switches.....all good.
I don't know where to go next on this problem.
Appreciate any guidance.
Thanks!
Thanks!
