Guys, I bought a 94 Aspy and the Left Saddlebag lid door does not fit properly. The bike had been laid down by the P.O. So I am thinking maybe the lidwas damaged or the P.O. purchased another lid to get by with. Well I order a used lid from a 95 GW. And it does not fit well (flush in the back or the sides.) just like the lid that came with the bike from P.O. Well I am confused. Was there a change in the years to the Saddlebags or is there some kind of adjustment needed to made the lid fit well. The lid does not lid well and flies open all the time. H---EEEE---LLLLL----PPPPP
The lids were never changed. If you re-used the old hinge, you will probably find it is bent from the fall.
Senior Guru
+1 just dont try to strighten it with it still attached to the lid as you may crack it plus there is a small amount of ajustment on the hinge fittings at the screws that hold them in
I have a 94 SE I bougt some hinges off ebay to chang mine they did the same thing. is the front closeing right
I agree the hinge is bent or the hinge mounting area is damaged. Compare with the other hinges on the other side. They might give you some clue.
