When I start my bike up, everything works. The minute I start to move, I no longer have tail lights, brake lights nor turn signals. When I come to a full stop at a stop sign, everything starts to work. Is there a sensor on the speedometer? My bike has been at a repair shop since Labor Day and they are stumped. Help is needed.
It is probably a ground connection in a large connector under rear of the seat, can't remember the color or # of pins but look for a connector with some green wires, pull it apart and check the connections.
Other side of the pond
I would go with the bad ground theory.
Problem fixed, I printed out the page that said it was the large connection under the seat and took it to the cycle shop. When we pulled apart the connector, THERE IT WAS!. One of the green wires was burnt. Looks like the problem is solved . Thanks for everyones help. BACK ON THE ROAD AGAIN.
